The zone fill and zone stamp act as one element, but the zone stamp is always above the zone fill.
You can place a solid fill and by default it will be above the zone fill but below the zone stamp.
If you use the 'Bring To Front' (or enough 'Bring Forward') command, the fill will hide the text but also the zone fill.
You can't have it hide the text but not the zone fill.
But if your intent is to hide the zone fill and the zone text, yes it can be done.
Also zone fills use RGB colours whereas a normal fill uses standard pens, so you may not be able to match fill colours if you need to do that.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
