2013-08-27 05:16 PM
2013-08-27 05:51 PM
2013-08-27 10:41 PM
laszlonagy wrote:
You can extract the ArchiCAD Library LCF to your hard drive. Then you can rearrange its folders and then create an LCF again.
This will hoever cause that if there is a Library Hotfix it will not be able to update because you changed it. So you may save a copy of the LCF and manipulate that. In that case, when there is a Library Hotfix you will probably need to redo those folder customizations.
Project-specific objects should be placed into the Embedded Library, that guarantees that they will always be available for the Project.
It is probably a good idea and easier/cleaner to manage if you just leave the ArchiCAD default Library alone, then load it, plus load any Office Libraries, and store project-specific objects in the Embedded Library.
2013-08-27 11:03 PM
2013-08-28 02:21 AM
2013-09-01 02:41 AM
2013-09-01 02:40 PM
SimpleTwig wrote:Yes. Save the file after making the changes to the parameters to set the defaults.
In order to change some of the default parameters of an object and the way it looks in plan, specifically it's default fill, could I double click on an object to open it, select 'Parameters' (I think) and select a different fill type than it's current default of 'Fill 85: solid + dot&dashed'?
Is this correct and the best way of setting the defaults of an object?
2013-09-01 07:16 PM
2013-09-01 07:30 PM
2013-09-27 09:05 PM
Subject | Likes |
6 | |
4 | |
3 | |
3 | |
3 |
