If you have build 1210 and have the full 11 library loaded, then the most likely culprit is that you have modified your attributes, particularly the fills, perhaps deleting some that the library defaults are looking for?
Look at one of your problem doors, for example, Door Settings (cmd-T), Floor Plan and Section panel, CUT SURFACES group.
If the checkbox for "Enable Object's Attributes" is NOT checked, verify that Cut Fill does not show as "missing". If it IS checked, go to the Parameters, Floor Plan Symbol and find the Symbol Fill Type - verify it is not 'missing'. Under 3D REPRESENTATION verify that no fills there report 'missing'.
Just one idea anyway...
Karl
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
