SOLVED!
Modelling a window: symbolic view
Hi there! I am modelling an old building where windows are aligned to the outer side of the external walls, and there are internal shutters to every window too. I have modelled both of these items separately and overlaid them, which has worked fine. However, I need to show the windows as symbols in order to display the window-swing-opening (dashed lines), but whenever the windows are displayed as symbols, these strange lines appear at the edge of the window. What are these lines and how do I get rid of them? Any tips or tricks? Or alternative modelling suggestions for getting rid of them? Have attached a screen grab for reference. Many thanks in advance!
1 ACCEPTED SOLUTION
Solution
Try the ganging options in the window settings.
6 REPLIES 6
Are these regular or custom windows?
Hi Braza, these are regular windows from the archicad 23 library
Solution
Hi Braza, thanks for your reply - but I can't find that settings dialog you show in your response anywhere... it looks like just the thing I need!
Hi again Braza, I found the relevant tick-box! Thanks so much for your help was losing my mind haha
Sorry Watsons. Didn't notice you are on AC23 POR.
I am glad it still helped you. And welcome aboard
Learn and get certified!
