Properties not working with multiple choice Option Set
JGoode
I have a zone stamp in AC21 that requests properties to display in floor plan.
All works perfectly fine until you select a multiple choice option set and then untick all options.
The Graphisoft Zone Stamp seems to not have this issue but I can't seem to fix it.
Here is the script for this:
! Get the value(s) of the stored property
!======================== 1
_valueString = ""
dim _propertyValues[][]
_dim1 = 0
_dim2 = 0
n = REQUEST ("Property_Value_Of_Parent", myProperty, _type, _dim1, _dim2, _propertyValues)
if n then
	! change zeros to ones - it is easier to handle all possible arrays in a double loop
	if _dim1  = 0 then _dim1 = 1
	if _dim2  = 0 then _dim2 = 1
	for i = 1 to _dim1
		for j = 1 to _dim2
			if (i + j) > 2 then _valueString = _valueString + "; "
			if _type = 4 then		! Type is string - no conversion needed
				_stringPropValue = _propertyValues
			else	! bool, real, integer types - conversion needed to string
				_valueToConvert = _propertyValues
				gosub "convertToString"
			endif
			_valueString = _valueString + _stringPropValue
		next j
	next i
endif
END
!====================================== 1
"convertToString":
	_stringPropValue = ""
	if _type = 3 then		! Real number to string
		_stringPropValue = str ("%.2", _valueToConvert)
	endif
	if _type = 2 then		! Integer to string
		_stringPropValue = str ("%.0", _valueToConvert)
	endif
	if _type = 1 then		! Boolean to string
		if _valueToConvert = 1 then
			_stringPropValue = `True`
		else
			_stringPropValue = `False`
		endif
	endif
return
Any help would be much appreciated.
Thanks
ArchiCAD 23
Windows 10
0 REPLIES 0
Learn and get certified!
