LucaP
Schedule scheme sorting settings issue
Hello everybody,
I have this annoying problem when setting up the Fields parameters in Schedules (also in Project Indexes). When you select multiple Fields you are able to change its settings together (for example sorting). Unfortunately even though during that operation everything seems to be working fine and all the settings change accordingly it seems that you are only changing the first Field options, because when you click OK and come back to the settings all the other Fields settings remain unchanged.
That seems like a bug to me - perhaps not the most urgent one, but annoying nevertheless.
Here are the screens of what I am trying to do in one go
And here is the outcome when I accept and come back to the Settings (only the first Field updates)
I hope this could be easily resolved.
All the best to everybody!
Operating system used: Windows 11 25H2
Łukasz Pietraszko
ArchiCAD 28 PL, since AC20 | WIN 11 Pro
Intel Core i7-14700K 3.4 GHz | 64 GB RAM | NVIDIA GeForce RTX 4070 SUPER 12 GB | 2 TB SSD
runxel
@James B Maybe something to look into. Could be an easy win, indeed.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
James B
Will check, in AC29 we made a number of general fixes as well.
James Badcock
