This may be related to a problem I have been complaining about since version 10 I think.
Used to be fine back in 8.1
Beams sitting on the edge of a column that continues up behind it do not mitre correctly.
Beams on there own are fine.
Straight beams are fine.
It is only in a corner situation.
One beam will cut away corectly but the second beam seems to undo part of the cut on one side of the referenc line.
Solid Element Operations are the only way I can solve the problem.
