half court basketball court. Must have! deadline.....
Does anyone know where to get a basketball half court or how to edit the full court already in Archicads library. Thank you.
Much needed as soon as possible.
4 REPLIES 4
You're in a hurry, right?
I cut the stock court in half, and modified the 2D script to take a snapshot of the 3D. That means the symbol won't work as expected. (and the goal shows up in the plan, which isn't ideal, but you could patch it.)
HTH,
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
Thomas Holm
Is it possible to cut that object in half (hide half of it) with a Solid Element Operator?
Steve Jepson
beware. there are different sets of dimensions for different kinds of basketball courts. NBA, International, NCAA men, NCAA women, WNBA, High school... check with Architectural Graphic Standards page 774 and tweak your drawings as may be required.
Thank you all so much for your help. I will definitely remember that info. I will not however bore you with the humorous and very generic solution I came up with for the immediate need. I will use your knowledge and go back and fix my project. Thankyou once again for all your help.
