Project data & BIM
modules
horror of horrors, i have opened a file up to find that it is a hotlink of itself. it must have been when i used the thick marquee to export all stories as a module and now it seems each story is a module. If i delete the module in the hotlink list then the drawing goes with it. Can it be reverted back to the drawing state or am i stuck with the module?
4 REPLIES 4
David Pacifico
Try this after doing a save as.
You should be able to select the module. (make sure to turn grouping on) Then from File/Modules and Xref's/Module Settings
In the dialog box check Break Hotlink of Selected Modules.
Otherwise if you know where the module is saved you could simply merge it a file.
Modules are such a great feature in ArchiCAD. Lots one can do with them.
Hope this helps
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
tried that, it doesnt work. The file is looking at the module for the drawing, ie the drawing is now a module. If i delete the module then the drawing goes too.
hang on, i tried that again and i think it has worked
Aussie John
check grouping is on
Cheers John
[/size]
Learn and get certified!
