Archicad C++ API
ACAPI_Element_UnLink issues
After used ACAPI_Element_UnLink to delete all links of an element , the number of the links got by ACAPI_Element_GetLinks is still not zero.
(The links is created and deleted by the same add-on, alos set undo functions )
8 REPLIES 8
Ralph Wessel
Mentor
Are you first calling ACAPI_Element_GetLinks to retrieve a list of linked elements, and then repeatedly calling ACAPI_Element_UnLink to remove each link? Does ACAPI_Element_UnLink return an error? And are you sure the guid_linkFrom and guid_linkTo parameters are in the right order?
Ralph Wessel BArch
Yes, I am first calling ACAPI_Element_GetLinks, and then calling ACAPI_Element_UnLink one by one, and sure ACAPI_Element_UnLink returns no error, and sure parameters are in the right order
Ralph Wessel
Mentor
I'm not sure what else to suggest - this call works for me. Which version of ArchiCAD are you developing for? Can you post some of the essential code that demonstrates this problem?
Ralph Wessel BArch
AC13.
err = ACAPI_Element_Get (&element);
API_Guid		linkFrom = element.header.guid;
API_Guid**		linkToList = NULL;
err = ACAPI_Element_GetLinks (linkFrom, &linkToList, &nLinks);
   for (GSIndex index = 0; index < nLinks; index++) {
   err = ACAPI_Element_Unlink (linkFrom, (*linkToList)[index]);
BMKillHandle ((GSHandle *) &linkToList);
Int32 nLinksTemp = 0;
err = ACAPI_Element_GetLinks(linkFrom, NULL, &nLinksTemp);
// There nLinksTemp is not zero
Ralph Wessel
Mentor
wcyoot wrote:
AC13.
That looks OK to me. Are you doing this within an Undo session, i.e. using ACAPI_OpenUndoableSession?
Ralph Wessel BArch
Yes, Of course. I am sure.
Ralph Wessel
Mentor
These functions work for me, so I don't know what else to suggest. I recommend cutting the add-on functionality down to the bare minimum required to test this code. Then you can be sure that the problem isn't caused by some earlier corruption.
Ralph Wessel BArch
In my test, there is nothing else to do.
Maybe it is a bug.
