2020-08-02
04:53 AM
- last edited on
2021-09-15
12:55 AM
by
Noemi Balogh
Solved! Go to Solution.
2020-08-03 01:17 AM
2020-08-03 04:23 AM
Viktor wrote:Hey Viktor, thank you for this info!
You can set the PythonUI/CustomLocation (String Value) registy key to the location of the interpreter.
2020-08-04 06:50 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-08-04 01:28 PM
2020-08-05 04:56 AM
Minh Nguyen
GRAPHISOFT
2020-08-10 02:42 AM
runxel wrote:Hi,
Viktor wrote:So what I did instead was making a new key named "PythonUI" inside of Computer\HKEY_CURRENT_USER\Software\GRAPHISOFT\ARCHICAD\ARCHICAD 24.0.0 GER R1\
And then a new string value named "CustomLocation" set to the path to the custom Python interpreter.
This however didn't work out, either....![]()
2020-08-10 03:06 AM
Tibor wrote:
The registry key should be created and set manually, so you did well.
2020-08-10 03:47 AM
runxel wrote:Thank you for pointing out this issue!
Seems like the registry key only helps, if AC already found an interpreter, otherwise it doesn't work – which is quite useless in a case like mine...
2020-08-10 04:05 AM
Tibor wrote:Great! Thanks again, Tibor! 🙂
You're absolutely right. I added this to our bug database
