2019-03-01 12:36 AM
Solved! Go to Solution.
2019-03-02 12:24 AM
2019-03-01 04:21 PM
2019-03-02 12:24 AM
2019-03-05 03:08 AM
2019-08-05 07:06 PM
2019-08-06 05:01 AM
gavinNZz wrote:Could you clarify the context in which you would like to modify parameters, i.e. broadly the application within a specific workflow? That function will be applicable to many workflows, but not all.
Would this functionality you talk of work in the case of a live connection with the parameters of a selected object?
2019-08-06 03:13 PM
Ralph wrote:Basically when a custom object is selected at any point in a workflow it would, through an AC add-on, expose its parameters to a xml file which would be read and written to by the external software which in turn would feed updated parameters back into the XML and, through the AC add-on, the object would be updated.
2019-08-06 03:24 PM
2019-08-07 02:37 AM
Ralph wrote:Thanks Ralph, good to know, just have to learn C++ now......ummmmm.....might be sometime!
Yes, that should work. Use this in conjunction with notifications from ARCHICAD of a selection change (and possibly editing if relevant).
2019-08-07 03:00 AM
