2023-01-13 10:52 AM
Hi Guys,
Is it possible to extract Properties from Building Materials?
I want to use this in a Label and process the data further as part of my Temperature Label:
https://www.linkedin.com/posts/debruinbimproductspecialist_archicad-activity-7016077546198818816-0Kz...
With kind regards,
Jeroen de Bruin
2023-01-16 09:52 AM
2023-01-16 10:24 AM
BUILDING_MATERIAL_INFO is only for (old) physical properties.
Other properties can be read with COMPONENT_PROPERTY_VALUES_OF_PARENT.
The code needs to know the IDs of the requested properties, currently the only way is that the user must select them on the UI. You can show a list on the UI using COMPONENT_PROPERTY_TREE_OF_PARENT. You also need to get the list of building materials in the labelled object with COMPONENT_IDS_OF_PARENT.
For an example see Archicad Library's Component Classification and Properties Label.
2023-01-23 11:39 AM
Hi Peter,
Thanks. I looked into this Component Classification and Properties Label, but that is next level GDL-stuff. Could you help me out a bit?
For Instance, I would like to get the number out of the Building Material Property 'Vapour Pressure'. How would you build that?
thanks in advance!
Jeroen
2023-01-30 10:49 AM - edited 2023-01-30 10:49 AM
With a parameter called "prop":
UI:
DICT propFilter, propTree
propFilter.propertyType = "ACPROPERTY"
n = REQUEST ("Component_Property_Tree_Of_Parent", propFilter, propTree)
if n > 0 then
_propertyName = ""
n = REQUEST ("Property_Name", prop, _, _, _propertyName)
ui_custom_popup_infield "prop", 0, 0, 300, 19,
1, propTree.treeDepth, 1, _propertyName,
propTree.propertyTree
endif
ui_outfield prop, 0, 20, 300, 20
2D:
dict collectComponents
collectComponents.collectMode = 1
dict outputCompIds
n = REQUEST ("Component_IDs_Of_Parent", collectComponents, outputCompIds)
if n > 0 then
for i = 1 to vardim1(outputCompIds.componentIds)
dict compPropInput, compPropVals
compPropInput.componentId.id = outputCompIds.componentIds[i].id
compPropInput.propertyIds[1].id = prop
n = REQUEST ( "Component_Property_Values_Of_Parent", compPropInput, compPropVals)
if n > 0 & compPropVals.propertyValues[1].value_status = 1 then
text2 0, i, compPropVals.propertyValues[1].value[1]
else
text2 0, i, "no value"
endif
next i
endif
2023-05-16 09:33 AM
I have a question about the Temperature Label: is the position of the object automatic or do you have to place it by hand?
I was wondering about the ability of a GDL label to find the geometry of a wall and position itself in relation to it.
2023-05-22 02:29 PM
the wall reference line is available as LABEL_ASSOC_ELEM_GEOMETRY .
A label can draw at given coordinates if the pointer is turned off, otherwise the drawing will be moved to the end of the pointer.
Use this code to transform from label coordinate system to project coordinate system:
! Transform from label local coordinate system to plan orientation and origin
rotBy = -LABEL_ROTANGLE
_unused = REQUEST ("View_Rotangle", "", angleViewRot)
corr = 0
if AC_bLabelAlwaysReadable & (AC_LabelOrientation = 1 | AC_LabelOrientation = 2 | AC_LabelOrientation = 5) then
summarot = (LABEL_ROTANGLE + angleViewRot) % 360
if summarot > 90 & summarot <= 270 then corr = 180
endif
rot2 rotBy + corr
add2 -LABEL_POSITION [1][1], -LABEL_POSITION [1][2]
