Developer forum
GDL coding questions, Python and add-on development using the API Dev Kit.
GROUP BY in sql query
Hello !
Try to create some simple query.
I need to sum some parametrs and use GROUP by command
But when I try to execute - fail.
unexpected token: GROUP в [строка: 1, столбец: 70]
My query:
select h.PARAMETERS.name   from flat( OBJECTS,PARAMETERS) as h
group by h.PARAMETERS.name
It is working?
And one more question.
How I can storage queries in project ?
1 REPLY 1
Mihaly Palenik
as Ákos Somorjai said in this topic (archicad-talk.graphisoft.com/viewtopic.php?t=57029),
the SQL queries are not supported any more officially (the last supported version was ARCHICAD 18 ), so don't rely on them.
Could you explain exactly what would you like to store in project file? Just the string of queries or something else?
Best,
Mihály
