2020-11-24 08:20 PM - last edited on 2021-09-15 09:29 AM by Noemi Balogh
Solved! Go to Solution.
2020-11-25 02:30 AM
If GLOB_SCRIPT_TYPE = 2 or GLOB_SCRIPT_TYPE = 3 or GLOB_SCRIPT_TYPE = 4 or GLOB_SCRIPT_TYPE = 5 then _nComponents = 0 dim _componentTypes[] n = REQUEST{2} ("Profile_components", myProfileIdx, _nComponents, _componentTypes) n2 = REQUEST ("Profile_default_boundingbox", myProfileIdx, _xMin, _yMin, _xMax, _yMax) n3 = REQUEST{4} ("Profile_component_info", myProfileIdx, _nComponents, "gs_profile_surface", bMat_profile) If GLOB_SCRIPT_TYPE <> 5 then If rafPro = "Complex" then ProWidth = abs(_xMax - _xMin) ProHeight = abs(_yMax - _yMin) SquareV2 = ProHeight / ( cos(phi) ) endIf endIf if n then dim _bShowPart[] _needRequestDetails = 0 for _i = 1 to _nComponents _bShowPart[_i] = 1 if GLOB_STRUCTURE_DISPLAY = 1 AND _componentTypes[_i] <> COMPTYPE_CORE then _bShowPart[_i] = 0 ! GLOB_STRUCTURE_DISPLAY: 0 – entire structure, 1 – core only, 2 – without finishes if GLOB_STRUCTURE_DISPLAY = 2 AND _componentTypes[_i] = COMPTYPE_FINISH then _bShowPart[_i] = 0 if _bShowPart[_i] then _needRequestDetails = 1 next _i if _needRequestDetails then dim _profileGeometryRawData[] n = REQUEST ("Profile_default_geometry", myProfileIdx, _profileGeometryRawData) ! n1, n2, ..., nn, x11, y11,s11 dim _contStartPoints[] dim _contEndPoints[] _contStartPoints[1] = _nComponents + 1 for _i = 2 to _nComponents _contStartPoints[_i] = _contStartPoints[_i - 1] + _profileGeometryRawData[_i - 1] * 5 _contEndPoints[_i-1] = _contStartPoints[_i] - 1 next _i _contEndPoints[_nComponents] = vardim1(_profileGeometryRawData) endif endif endif
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win10 | R5 2600 | 16GB | GTX1660 |
2020-11-25 02:30 AM
2020-11-25 04:07 PM
Lingwisyer wrote:Check out this thread: Profiles in GDL.
There is a sample object somewhere by Graphisoft, but it appears to be alluding me...
2020-12-03 08:32 PM
Lingwisyer wrote:
There is also an object shared in this thread which is in regards to having multipleComplex Profilesin a single object.
2020-12-04 02:24 AM
