Archicad C++ API
How to call ACAPI_Automate(APIDo_SaveID) inside ACAPI_CallUndoableCommand scope?
Hello guys,
I call a function in ACAPI_CallUndoableCommand scope and inside this function I call ACAPI_Automate(APIDo_SaveID) and ACAPI_Automate is not working:
ACAPI_CallUndoableCommand("Import Files", [&]() -> GSErrCode { ImportFiles(); return (0); });
void ImportFiles()
        ACAPI_Automate(APIDo_SaveID);
Is there a way to get out of this scope or I have to call it outside ImportFiles?
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
APIDo_SaveID is not allowed to be called inside ACAPI_CallUndoableCommand scope.
Sorry, you have to call it outside.
Regards,
Tibor
4 REPLIES 4
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Regards,
Tibor
In order not to open a new topic for these automated functions, how can I open a new project with the "rectangle area" in the center? I open a new project using the example and don't have it:
        API_NewProjectPars npp;
	BNZeroMemory(&npp, sizeof(API_NewProjectPars));
	npp.newAndReset = true;
	npp.enableSaveAlert = false;
	GSErrCode err = ACAPI_Automate(APIDo_NewProjectID, &npp);
If I manually open a new project, ARCHICAD 23 Template.tpl is choosen and everything is OK.
How can I choose this template with the automated function?
MOREH Tamas
Hi!
You are right it is currently not possible.
I register it in our issue tracking database and we will implement as soon as we can.
Thank you for the report.
Tibor,
If I understand this correctly, this prevents me from creating a custom menu [AC23] with a choice that updates all drawings and saves.  I understand I have to reserve before I can save a Teamwork file.  However, I am the only one working in a non-Teamwork .pln file.  I am using Do_Save_Plan() found in the AC23 Examples Automate_Functions.cpp file.
It would also be unclear to me if I cannot call this from inside the ACAPI_CallUndoableCommand scope of MenuCommandHandler(), how exactly would I execute my update instructions and save my work?
Currently, when I try this, I get err = -2130312312
GSErrCode __ACENV_CALL MenuCommandHandler (const API_MenuParams *params)
 return ACAPI_CallUndoableCommand("JHP_BatchPdf Menu Command", [&]() -> GSErrCode {
  switch (params->menuItemRef.menuResID)
   case JHP_BATCHPDF_MENU_STRINGSID: {
    switch (params->menuItemRef.itemIndex)
     case 1: {
      ACAPI_WriteReport("Refresh", true);
      RefreshAllLayoutBooks();
      break;
     case 2: {
      ACAPI_WriteReport("Save project", true);
      Do_Save_Plan();
      break;
     case 3: {
      ACAPI_WriteReport("Save PDF", true);
      Do_Save_PdfFile();
      break;
  return NoError;
// Save the current project
static void Do_Save_Plan(void)
 GSErrCode err;
 err = ACAPI_Automate(APIDo_SaveID);
 if (err != NoError)
  // ACAPI_WriteReport("Error in APIDo_SaveID: %s", true, ErrID_To_Name(err));
  ACAPI_WriteReport("Error in APIDo_SaveID: %d", true, err);
 return;
} // Do_Save_Plan
Thanks for any hint you can provide,
Chris
Chris Gilmer
Intel i9-12950HX CPU @ 2.30GHz, 16 cores
NVIDIA GeForce RTX 3080
48.0 GB RAM
Windows 10 Pro 64-bit
