2022-04-13 08:21 AM
I would like to have a editable hotspot to move only by given values but obviously I get a numeric error when I check the script.
Is there a way to "limit" the hotspot's movement to the given values only?
Practical example 🙂
On the parameters tab I have this:
VALUES "Height", '1420', '1580', '1880', '2120', '2280', '2990'
On Master:
unID = 1
On the 3D script
HOTSPOT 0,0,0, unID, Height, 1+128
unID = unID+1
HOTSPOT Height,0,0, unID, Height, 2
unID = unID+1
HOTSPOT -1,0,0, unID, Height, 3+128
unID = unID+1
Juan.
Solved! Go to Solution.
2022-04-13 09:06 AM - edited 2022-04-13 09:06 AM
The hotspot movement is a length, so your 'Height' parameter needs to be a 'length' type and not 'text' type.
The value list will be lengths in meters with not quotes ...
VALUES "Height", 1.420, 1.580, 1.880, 2.120, 2.280, 2.990
2022-04-13 09:46 AM - edited 2022-04-13 10:34 AM
You could use Range and Step to do something along the lines of
VALUES "Height" range [1, 3] Step 1, 0.2
Ling.
Win10 | R5 2600 | 16GB | GTX1660 |
2022-04-13 09:14 AM - edited 2022-04-13 09:14 AM
Ohh, that easy, thank you. I need to take a break 😅
2022-04-13 09:16 AM
I hope is ok to ask another question here since it is somewhat related. If not the mods are free to move it to a new topic.
Is it possible to give a max and min lenght limits to the hotspot and define the movement steps?
Juan.
Ling.
2022-04-13 10:01 AM
Thank you, sadly I get an error:
Juan.
2022-04-13 10:34 AM
Probably bad syntax on my part. I have not used the values command with range and step before. Updated previous post with what I think is the correction. Had an extra comma.
2022-04-13 10:58 AM
Fantastic, thank you 🙂
