GDL
Object Postion
Is it possible to define these parameters in a GDL part in the same you are able define a,b and z setting
No because that is not a parameter of the object.
It is the 'Z' position that you need to specify when placing an object - the same as you specify the 'X' & 'Y' position.
But you can negate this by using ... ADDz -GLOB_ELEVATION
Didn't this crop up in another post the other day?
https://archicad-talk.graphisoft.com/viewtopic.php?f=49&t=72368
Thanks Barry though that might be the case
Goker Altuntas
Yeah, definitely
text2 0, dy * 2, "Goker Malik Altuntas"
