‎2021-03-12
05:25 PM
‎2021-09-14
09:46 AM
Noemi Balogh
add 0, 0, -GLOB_ELEVATION + hStandard
block 0.1, 0.1, 0.1,
del 1
This would probably solve the issue but I would prefer ArchiCAD to understand where the actual geometry is. Is there anyway to adjust or maybe just stabilise -GLOB_ELEVATION parameter itself?‎2021-03-12 09:55 PM
‎2021-03-12 11:08 PM
The global elevation is going to change anytime the object shifts inside us z-spaceYes, and that's what I don't want to happen. Or in other words, I need to restrict the object to not shift vertically. In our projects, this object has to be located at a specific elevation which is 1437mm above the home story. It is a difficult number to remember all the time. Also, there are other objects which are needed to be located at different elevations.
‎2021-03-13 06:09 AM
‎2021-03-14 02:44 PM
SenecaDesignLLC wrote:Thanks for all your suggestions. I will check the elevator asap
You should for sure look at the elevator object then, As it will give you the code you need to access locking your object to a specific height above the home story
