Mihalcea Bogdan
3D shape inside another 3D Shape.
Hi!
I have 2 objects a cylinder and a cube. The cube smaller that the cylinder and is located entirely inside of the cylinder.
The 2D view generates a preview where only the cylinders top is visible.
Is there any way to make archicad understand that i need the both of them to show up in the 2D top view? Possibly with very little code because the cube sometimes is another complex object.
1 Solution
Jochen Suehlo
You can write a 2D Script or you can try PROJECT2 3, 270, 1 (with 1 at the end for "wire frame")
If you still do net see the inner shape with this PROJECT2, you can try Solid Element Operations in 3D.
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
Go to post
Jochen Suehlo
Mihalcea Bogdan
Thank you, solved my issue!
