2016-08-11 01:52 PM
2016-08-12 10:26 AM
DrWho wrote:No, the API won't support this kind of change.
I would like to modify the W/E by either changing the layout, shape and size of the drop down menus or adding a "ribbon" like in the MS products. I'm just not sure this can be done as an "addon". Any thoughts?
2016-08-12 01:13 PM
2016-08-13 11:43 AM
DrWho wrote:Yes, the downloaded developer resources are the public API. You won't be given private APIs, which are essentially part of the core source code for ARCHICAD. It wouldn't be advisable to use them anyway because they might change for even intermediate hotfixes, breaking your add-on without any warning.
Thanks for the response Ralph. Can I assume that the developer's API that is downloadable is not the same as the API that the actual developers use? If so does anyone know if it is possible to download that API
