Document & Visualize forum
BIMx flow
christkenddy
Hello
Just wondering how to get the BIMx file with out a Graphisoft license to log into. Can I not just save to desktop, upload it to my onedrive then view it in the app?
I have a windows tablet that is running an android emulator so I can get the BIMx app. Drag and drop does not seem to work.
Kenddy mini militia
chiara
  1. Make a publisher set for BIMx export
  2. Open Publishing Properties
  3. Check 'Save Local Copy' and select a path and destination folder. By using a dropbox/onedrive folder you can import this file by clicking on the '+' sign in the BIMx application.
https://help.Graphisoft.com/AC/25/INT/index.htm?rhcsh=1&rhnewwnd=0#t=_AC25_Help%2F100_Visualization%...
Michel Janssens,
Project Architect, BIM Manager
a2o-architecten
https://www.a2o-architecten.be
ArchiCAD 8-25 NED FULL KME
Macbook M1 PRO
4dProof
you have to use the publisher now, no save as option. set the publisher properties to "save file", not "publish BIMx hyper model". Then set the publishing type to "single file" and the format to BIMx. Save a 3d view to the publisher set, and set the file save destination to your computer or network, and publish
BIM solutions and trouble shooting (self proclaimed) expert
