As far as I know that is an Operating System setting.
So unless you changed something there recently it should not have changed.
The problem with this is if you turn it on/off then it may be different if you open the same file on another machine.
Turning the comma off will not affect existing dimensions, so you will now get a mix.
At least this is what used to happen years ago when I looked at it.
