Document & Visualize forum
Exporting lists of objects, including classification and parameters
Konsis
Hi all!
Is there a way to generate a list of the objects used, including the amount of each object, and the information assigned in the "product information" under "classification and parameters" tab in the object settings?
I hope to enter product name, supplier and price in this tab, and then easily export a list of all i.e. furniture I've used.
Tips?
AC 26 - iMac 2023 iOS Ventura
DGSketcher
Champion
You may want to look at this link to get you started... Interactive Schedules
You could also consider signing up at Graphisoft Learn if you are new to Archicad
Apple iMac macOS Ventura / AC26UKI (most recent builds)
Konsis
Thanks! I'll have a look at the link.
Not new to Archicad at all, just never worked with lists before. Thought it might be time saving if I can get it to work the way I want... 🙂
Be careful of the terminology used.
'Lists' are something a little different - old method used before we had the 'Interactive Schedules'.
They still (sort of) work but are no longer being updated - so don't work with any of the new tools.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
