amh_caspar
Parameter transfer of classification and properties not working - AC 27 BUG?
Hi everyone,
I am trying to use the parameter transfer tool to transfer classification and properties from morph objects to other Building Elements.
At first in the Element Transfer settings I just had ticked the boxes for classification and properties but when this didn't work I ran a few tests with transfer all settings applied but still in every test the classification is not transferred. Other settings are transferring just fine. But Classification is not.
Is this is a bug? Or maybe someone has an idea why this isn't working.
Operating system used: Windows Windows 10 Pro
Settings transfer works only from an element type (e.g., Morph) to an element of the same element type (another Morph).
Try the Edit Selection Set Dialog, (Edit > Element Settings > Edit Selection Set menu command or CTRL+SHIFT+T key combination).
In that Dialog, you can set the Classification and Properties for multiple elements of different element types.
