2023-01-24 12:32 PM
Does anyone know a fix for the following?
I made a label that attaches to a Revit (.RVT) module file that makes a opening line for the door, it retrieves its width from the door width which is embedded in the revit properties. However, when I mirror the module, the label also rotates, does anyone know how to previt this?
The module on the right side, is the correct one
Kind regards,
Solved! Go to Solution.
2023-01-24 01:48 PM - edited 2023-01-24 01:49 PM
I fixed it, adding this will make it work:
IF SYMB_MIRRORED THEN
MUL2 -1,1
ROT2 180
ENDIF
