Publisher Set DWG option Missing
Katie101
Im trying to publish a DWG file, but when I go to Publish and choose The DWG publisher set and look at Publishing Properties and Format there are only 2 option BIMx Hyper-Model and PDF.
I have checked the Add-on Manager and the box is ticked, am i missing something?
Katie101
By the way Its Archicad 25 version 4014 šŸ™„
jan_filipec
Could you post a screenshot of your oublisher set? This usually happens when you try to publish a folder which includes non-drawing elements like lists.
Tim Ball
Perhaps you are trying to save several layouts as one file
Tim Ball
AC26, iMac
User since V5
