Kcorreia
Purge unused layers
Has the Purged Unused Layers option been removed in the most recent versions of Archicad (AC27 and beyond)? I no longer see that option in the Attribute Manager. Is there another location or function I am missing to achieve the same task?
1 Solution
It is still there.
But I am guessing you are opening the Attibute Palette - it is not in there.
Open the old Attribute Manager and you will see it is still there.
You may have to add the command for Attiribute Manager to your tool bars and menus in the Work Environment, as I don't think it is there by default.
Go to post
It is still there.
Kcorreia
That's exactly what I was doing....Thank you Barry!
