Visualization
twinmotion installation
Any body else had problems intstalling Twinmotion for AC 23 ?
Its been installed and appears in my tool bar above.
But when activated (direct link) it says not installed.
see image.
thanks all
4 REPLIES 4
vistasp
The Twinmotion application and the direct link are two separate pieces of software. Are you sure you have both? Can you open twinmotion 2020 independently?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
yes. good question though.
Are you sure you have the 2020.1 direct link installed?
The older versions will be looking for the older versions of TM, and if they are not installed that may be why it can’t find the program.
i will look in to versions yes. I let you know, thanks
Learn and get certified!
