visualization work
Jeremi
Will visualization work on intel core i5 (11400), 16 GB of RAM, nividia rth 3050 4GB ?If it works, how good is it (for apartments/ small private houses)
Guru
You should probably include a reference image of the quality level you are looking for as that will greatly affect the system requirements and / or time to render. Also, what type of renderer do you plan on using?
For Twinmotion, a 6+GB GPU is recommended, but the RXT 3050 is a decent amount faster than the minimum req so it might work. If you were wanting to do photoreal with something like VRay, you fall woefully short.
Ling.
Jeremi
I was interested in cinerender
