2021-10-27 02:28 PM
Hello!
One of the easy questions I think!
How come my 2D fill is not willing to allign to my slab?
I want to have a slab of insulation - is there any way to make the 2D fill fit into the section of this element?
Thank you!
Solved! Go to Solution.
2021-10-28 05:43 AM
Yes it must be a composite for the 'fit to skin' option to work.
And as Steve says, you can have a single skin composite.
2021-10-27 08:34 PM - edited 2021-10-27 08:41 PM
Could be a Building Materials setting? Try Fit to Skin.
2021-10-27 08:38 PM
Unfortunately it doesn't work the way I would wish it to work, since the fill is displayed in the way I l've presented on the s reenshots. This concerns the section views, not the plan views. And does not affect the composite structures. The slab I have modelled is a single layered one.
2021-10-28 03:58 AM - edited 2021-10-28 04:00 AM
If you need to scale your fill, use the 3rd option.
Ling.
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
2021-10-28 04:57 AM - edited 2021-10-28 05:09 AM
? Yes - the setting I am showing you does control how the patterns are fit to skin or to an origin in a Section. https://www.youtube.com/watch?v=t8ilMVxnmaU
Can you think of what makes this work? 🙂 in the video, they are both moved together up and down in a SECTION view. One has the Building Material Fill Orientation set to "Fit to Skin", the other Building Material Fill Orientation is set to "Project Origin" . In case the video does not work or some, the Fill/Building Material in one slab changes as the slabs are moving up and down, the other one does not. This is controlled by Building Material settings.
2021-10-28 05:04 AM - edited 2021-10-28 05:22 AM
Oh, that is an actual slab element not a 2D fill... Doesn't that setting require the use of composites? Only walls in Plan do not "require" this. So the issue here would be that Ged has used a Basic Slab rather than a Single Layer Composite?
2021-10-28 05:23 AM
The little trick is to use a (1) skin Composite 🙂 Then the Building Material setting for Fill Orientation can be set to "Fit to Skin" so it can stay looking like you want it.
2021-10-28 05:43 AM
2021-10-30 06:36 PM
Yes!
Thank you all for your replies.
The answer for my question is that this option doesn't work for a single layered elements in section views. You must use a 1 layered composite structure for the fill to allign to the layer.
That is a pity in my opinion, but hey, it works!
