2014-08-04 07:58 PM - last edited on 2023-05-17 06:32 PM by Gordana Radonic
2014-08-05 03:50 AM
2014-08-05 05:58 PM
2014-08-05 06:03 PM
2014-08-06 12:07 AM
2014-08-06 03:39 AM
rob2218 wrote:Does the model look OK in 3D with the Internal Engine active?
JUST SO YOU ALL ARE AWARE.....when migrating from AC11 to AC17...DONT DO IT.....it appears that this vast of a migration caused my 3D Documents, materials, surfaces..etc...to be all out of whack.
there's no way to get this thing back to normal either.....oh well, live and learn.
2014-08-07 12:34 AM
Barry wrote:rob2218 wrote:Does the model look OK in 3D with the Internal Engine active?
This is what 3D Docs will use.
YES...the model in 3D looks fine when I switch to the "Internal engine" as the rendering viewing look.
If it does then that is a problem.
Are you using the Building Materials or surface over-rides?
umm...not sure. this was an Archicad 11 legacy PLN which got opened and butchered in AC17
Do you have Legacy mode switched on (i.e. not using BMs) or off (i.e. you now have the choice of BMs or surface over-ride) - try both?
Where do I find this to switch on or off?
The Building Materials will be created automatically when you convert to 17 so maybe you need to check those and make sure that appropriate surfaces (the old materials) are assigned to the BMs.
2014-08-07 03:46 AM
rob2218 wrote:Options menu > Project Preferences > Construction Elements.
