I am not an expert with reno filters as I don't use them.
But if you need the 'Planned' filter for your view then you will need to look at the override settings in that filters so you fills are not being changed.
Otherwise just switch to the 'Existing' filter but make sure you make the change in the View Settings dialogue so it can be saved with the view.
Just changing the filter will change what you see on screen but as soon as you open a view again it will reset to what was saved in the view settings.
Lenovo Thinkpad -  i7-1270P   2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
