alegafs_92
3D View - How to hide doors frame lines
Hi everyone,
I want to hide the lines (the orange one) of the frame of the doors in the 3D View. I've managed to hide the opening lines but not the frame lines. How can I do it?
I have deactivated them in the View Model Options but it seems not to have any effect on them
I hope I've been clear, thanks a lot!
1 Reply 1
Miha_M
You can eliminate all contour lines in the View > 3D View Options > 3D Styles window, where you have to disable the Show Contours option.
You can't hide only this line, you can only change the color. This can be done within the library element settings, but the location depends on the library element itself. An example here:
| Archicad 4.5 - 29
