3D document cuts part of model
Kaj_AL
Hi!
I have a recurring issue, which is obviously something I'm doing wrong but I can't for my life figure out what.
I have a 3D Document isometric view. When I updated the view from 3D it got cut on the right side of the image, and I can't figure out how to get it back.
My workflow (which I don't know if it is correct) is this:
1. Update a 3D axonometric view in the View Map.
2. Right click on my 3D Document in the Project Map and click "Redefine 3D Document based on Current 3D Window"
3. Update them in my layout.
No matter how much I zoom in and out I still get a cut in the model.
Thank you for your help!
Archicad 24-27 SWE
Dell Precision 5560, Windows 11 Pro
11th Gen Intel(R) Core(TM) i9-11950H @ 2.60GHz 2.61 GHz
3 REPLIES 3
Right click in the 3D Document and choose 'Open 3D Source'.
Is there a cut plane or marquee cutting the corner?
If so, turn it off and then right click in the 3D window and re-define your 3D Document.
Thank you for you response!
In some way the issue was fixed without me knowing how it happened, and I can't replicate it again. They are not my best friends, the 3D documents.
/Kaj
Archicad 24-27 SWE
Maaike
i've figured out how to solve it. I could not find the planes that where cutting my model. However, archicad was still cutting half of my model.
How to solve this: Right click on 3d view > filter and cut elements in 3d > Maruqee effect turn trim elements to marquee off > ok. To keep this setting in the model, redefine with current window settings, otherwise it will be gone after you change views! After this you can publish your 3d document with the whole model in it
Setup info provided by author
