‎2009-09-21
03:48 PM
‎2023-05-23
12:01 AM
Gordana Radonic
‎2009-09-21 04:20 PM
‎2009-09-22 01:18 PM
Jesikuh123 wrote:I think that the dimension should update if it is an associative dimension point.
In 3D documents are dimensions supposed to change when you change the length or height of something?
I don't understand the "Y" value in the tracker.
where is the 0,0 in a 3D document?
When i use my elevation dimension it gives the correct "Z" measurement, but when I hold my cursor over it there is no "Z" value (it is greyed out) and the Y shows as a different number than my dimension.
Any ideas?
‎2009-09-25 12:14 AM
like the 3D document functionality itself-- is a real disappointment.Funny how your view of things depends on your perspective. Only recently coming from 2d CAD I think 3D documents are a revelation and awesome! The ability to be able to put a 3D document into a set of plans has been great. I don't generally dimension but use them mostly as a way of clarifying a complex detail or structural arrangement or just to provide hidden line external perspective drawings of the building.
