3D view on layout
Polar Bear
It's been three hours that i've been searching for a very simple thing: my 3D views placed on layout aren't clear!
I have seen some tutorials on enlarging the windows etc. But can't believe it's the way the software was designed to operate. Help please!
Thanks a lot!
Archicad 25 - 5010
Macbook pro 13" /Big sur 11.4 + External 4K 27"
Gerald Hoffman
Hi Polar Bear,
Are these 3D Document Views that you are trying to place? Or are they screen shots of 3D Views. Perhaps you could post an image of what it looks like.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 28-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
Polar Bear
Thanks
Here is an image.
It is views taken from 3D generic perspective onto a layout...
Archicad 25 - 5010
Gerald Hoffman
Polar Bear,
AFAIK the only way to reduce pixelation is to create a larger image as these are raster and not vector images. You can do a rendering and make the output size quite a bit larger and then shrink it down when placing on the sheet. If there is a better way I would like to know it to.
Gerald Hoffman
