canvea
3D view placed on layout is blank
I have a problem with 3d views showing up as white/blank when placed on a layout. I have tried Fit frame to Drawing, Full Precision Preview etc and they are on Auto-update. If I right-click and pick "Open source view" it looks just as it should in the 3D window. They also appear blank when I publish, which is a big problem. Am I doing something wrong or is this a bug?
Thanks in advance for any response!
Archicad 23, Windows 10 Pro, graphics card: NVIDIA Quadro P4000
AC24 Norway • Fujitsu • Intel(R) Xeon(R) W-2123 CPU @ 3.60GHz • 32GB ram • Windows 10 Pro • NVIDIA Quadro P4000
47 Replies 47
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you for the report and I am very sorry about the bad experience!
Once in a while, we had a similar report like this one. But due to the lack of a reproduction method, so far we were unable to reproduce the issue. Our colleague made a checklist on what we need to pay attention to for the investigation:
  • First, we would like to know the Archicad versions and OS you are using
  • Are the drawings set to auto or manual update? If it’s manual, does setting to Auto solve the issue?
  • Are they set Fit to Frame, Crop to Frame, or Manually Resize to Frame? Does changing on that setting help?
  • Does it happen after a particular step (e.g. publishing, saving etc.)? Could you point out anything, after it changed?
  • Does it happen in Teamwork only or on the Solo file too?
  • Was there any recent operating system update?
  • If it’s a Teamwork file, does it happen to everyone simultaneously?
  • Does it happen to all projects on the same computer or only one?
  • Are all graphic card drivers updated? Is the drawing missing from the published PDF/printed document?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Patrick M
thank you for your response Minh. I totally understand the difficulties in trouble shooting something that is so random and spotty. I have tried for years to find a consistent trigger for this issue.
-this has been an issue ever since 3d views have been able to be placed to a layout, as far as I can remember. I don't recall a version of Archicad that didn't have this issue.
-this issue happens with auto AND manual update. It is particularly frustrating when set to manual, as you go through the trouble to update drawings, publish, then realize your 3d views are blanks on the PDF set you are about to send to a client/contractor
-again, it happens consistently with all crop/resize/scale/fit settings
-No consistent step triggers this. Sometimes they go blank after updating. Sometimes they show blank immediately after placing. Sometimes they just appear blank after opening a layout.  There is no obvious trigger or consistent step leading to this issue.
-Teamwork and .pln equally
-I have been using AC for 15+ years, on every Mac OS and one Windows OS, and EVER AC release/build over that 1.5 decades, and it has happened, as I said before, since we have been able to place 3d views to layouts.
-For t/w local data, it does appear to work for some users and not for others, so it isn't tied to server data; but the fact that it happens in .pln, .pla, .mod files in equal measure would indicate it is somehow a local data issue anyway. It will work for one computer and not for another even when both computers have identical install, software, hardware, and OS configurations.
-It does not happen to all projects open in separate instances at the same time. It appears to be completely random.
-Graphic card drivers are across the board... and yes, it is missing from the published pdf or printed document.
Ultimately, this is an issue with releasing software with unresolved features and capabilities. I wouldn't mind if I simply had to save a .jpg/.png or place as a 3d document to get the perspective/axon onto a sheet. Those are viable work arounds that work consistently (even if they don't have a preferred graphic/appearance). It would be great to see GS whittle out all the shoddy half working "features" in order to get an authoring tool that was just a little more 'bullet proof'. I do a lot of consultation, helping users trouble shoot all kinds of things like this, and it does not reflect well on me or the tool I am trying to use when I have to tell a client "well, sometimes Archicad just sucks and craps all over your day like this". But that is often time the best I consolation I can give when things are so random and hit or miss like this.
Patrick M
I manage systems for a few offices. the biggest of which has nearly 50 users on various configurations. The issue persists or at least pops up on virtually all hardware/software/OS configurations, for virtually all builds of AC. The hard thing is, it works most of the time, but falls apart when I really need it to work (usually right before a deadline or a meeting)
Patrick M
thank you for confirming this is NOT a mac issue... tired of the frustration of dealing with the finger pointing at OS/Hardware as a scape goat
Stuart Smith
Can confirm this issue. Placing 3D views on layouts is unreliable. Sometimes it works, and sometimes it doesn't. There is no rhyme or reason.
Our workaround is to only place 3D Documents, but often they don't look as nice, and take longer to update, so it's not ideal. Plus it's an additional step to save the 3D View, then create a 3D Document.
Graphisoft, please investigate this issue!
AC user since 8.1
benjamin_chan1
I've had this happen to AC25 with latest build
it seems to happen on Teamwork files more often than solo for me
benjamin_chan1
I had it happen on a teamwork file just now, saved it as solo project, open and repair, problem fixed, but the 3D views resolution gets changed (and I have to resize them again)
I have a feeling it's to do with different computer's monitors' resolutions - AC gets confused when switching between different users (on teamwork) resolutions
Jp1138
Just had this issue in latest Archicad 25 4013 SPA. It was a solo file and I only noticed when published layouts came blank. Restarting windows made the trick. Weird.
ARCHICAD 29 SPA (as long as the server works)
Windows 10
designtech_julius
Is this resolved with the Mac version?
I'm having issues with this on my mac with Monterey 12.3.1.
Seems that I have to use windows version until there is a fix
AC 11-25
WIN 10 - Intel i7 - RTX 2080
MAC - MBP M1 Max
Yvonne
restarting window explorer fixed it for me. thanks! silly question but what does restarting window explorer do and why does it fix the views?
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
