2020-01-27
08:16 AM
2025-02-06
12:09 PM
Aruzhan Ilaikova
2020-01-27 10:55 AM
2020-01-27 11:31 AM
2020-01-28 02:24 PM
DGSketcher wrote:Yes but there's nothing else which can cause the disturb (that exists in every corner!). And as it is shown in image1 the wall does not contain anything else but itself.
Have you looked beyond the wall? It may be the unwanted graphics are related to the square filled area and structure below which is exposed when you remove the finishes. You may be able to rectify this by adjusting your view cutting planes or possibly turning off substructure or other layers.
Braza wrote:Of course I got some composite end lines, which effectively are in grey and not in black. But anyway there will be a fail in the whole contour and not just in the thickness of the plaster
Or maybe its related with composite end lines.
2020-01-28 04:36 PM
2020-01-29 06:56 PM
2020-02-01 05:30 PM
2020-02-01 05:51 PM
