AC 8.1R2 Problem
I'm having several problems using sections/elevations:
1- Draw a line that turned impossible to pick.
2- Can't use copy, multiply.
3- Mirror don't keep the original issue mirrored.
Somebody know how can I fix this?
Thanks
Eduardo Rolon
I'm using it with no problems. Try uninstalling both 8.1r1 and r2 and then do a clean install. Could be that the S/E objects that didn't update right.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Thank you, that could be because the other's PC have no problem.
__archiben
was your file started in an 8.0.x release of archiCAD? these were all issues that cropped up every now and then for me in those bad old days.
try merging your existing file into a 'new and reset' 8.1v2 file, or better still, try eric batte's 'forward merge' tip:
http://archicad-talk.graphisoft.com/viewtopic.php?p=4893#4893
this will hopefully have the effect of cleaning out bad attributes left over from early versions of archiCAD 8.
HTH
~/archiben
b e n _ f r o s t
