AC12: More Problems with Dimensions
Since moving to AC12, we've been having problems with Dimensions disappearing from Detail windows -- see this post.
Now we're having problems with Dimension Text moving itself around. Text of Dimension Chains, that are set to the default position, are shifting a number of feet away from that default position (see attached for example) -- this is a TW project, and the shifting usually takes place immediately following a Send and Receive. I've also had reports of Witness Lines moving, while the Dimension Points stay in place.
Anyone else experience this???
12 REPLIES 12
David Larrew
Yes, we were experiencing this in AC11 (at my old employer). I thought this was fixed in AC12???
I personally haven't experienced this since.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Huh -- we NEVER had a problem [with this] in AC11.
I seen my share of dimension quirkiness, but I haven't seen this in my own nor any of my clients' practices (since AC3.43).
Erika Epstein
I realize this is unlikely, but by any chance were these views saved when
Options>Project Preferences>Dimensions
had Revert all dimension Text to Automatic Position checked?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Wouldn't this have the opposite effect -- text that had been manually moved reverting back to the default position?
Erika Epstein
Yes. Your screenshot looked like it had gone back to default. Did I misunderstand?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Just the opposite -- Text in DEFAULT position has been MOVING.
Erika Epstein
Wow, not good, assume you have logged a bug report?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Will do.
