2012-02-07
08:30 PM
2023-05-26
12:06 AM
Gordana Radonic
2012-02-08 04:22 PM
2012-02-08 07:38 PM
2012-02-13 08:51 PM
Erika wrote:Hi Erika,
Do you get errors when generating the 3D model from the first floor view?
You may have to turn on errors in your work environment.
Try setting your placed drawing of the first floorand site plans to Manual instead of Auto Update so the program won't try to regenerate before creating the pdf.
2012-02-13 08:56 PM
Juha wrote:Thank you but no.
We once had similar crashing AC13 file. It turned out to
be the used built-in section marker, which freezed the file
every time we changed to the floor where the section marker
was placed.
Changing to different marker solved the problem.
Hope this helps.
2012-03-02 01:36 PM
2012-03-02 03:13 PM
