2017-10-12 10:50 AM - last edited on 2023-05-26 02:25 AM by Gordana Radonic
Solved! Go to Solution.
2017-10-12 11:05 AM
2017-10-12 11:05 AM
2017-10-12 11:09 AM
2017-10-12 02:30 PM
another Moderator
2017-10-15 04:31 AM
2017-10-15 02:49 PM
2017-10-15 06:39 PM
ejrolon wrote:Glad to see you're back Eduardo.
FYI,
Even if they are Red they will print correctly.
2017-10-16 04:07 AM
David wrote:That was a huge help David, thank you so much. The change from AC19 to AC20 has really thrown me and as a result I've hesitated to move on to 21 before the end of the semester.
Mitchell:
If you are placing Drawings (using the Drawing Tool) on Layouts, then open the Drawing Settings and look at Size And Appearance > Colors:, and also check Pen Set: (the Pen Set could be all black).
