AC26 missing cut fill issue in section views
Hello Beta Testers,
In AC26 INT 4019 and 5002 build having same issue in section views in random places.
Mesh and slab behaves strange and cut fills are missing for slab element. Made video about this issue, looks very weird behaviour while in one part of drawings it's showing cut fill but on another its missing. There are no other elements placed in that space that could cut out, when I remove mesh its looks all right.
This started to happen only in AC26 from first release. Does anyone else having similar issues with missing cut fills in section views in AC26 ?
When I place Elevation views and use them as section then there are no issues regarding cut fills.
Video below explaining how it looks:
https://youtu.be/nM-QG8z-cEI
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v28 INT / NOR (5030)
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
10 REPLIES 10
I would say that technically, Beams not intersecting automatically with Roofs is not a bug, because it is intended behavior. By "intended" I mean that this specific type of automatic intersection was not developed at the time, and it seems, no additional developments were done in this area of "automatic intersections based on Building Material priority" since.
So, I recommend that you create a wish for this functionality, so it can be voted on (with Likes) and submitted to Graphisoft for consideration.
