2025-09-10
06:06 PM
2025-09-10
10:40 PM
I am using AC 28.3.0 on macOS Sequoia on an M3 MacBook Pro. I have been having difficulty getting any skylight object to show up in the section view. All I see is the hole in the roof. It appears to be set to a simplified setting somewhere, but I cannot find where to adjust it that I haven’t already set. The detail skylight is visible in 3D. It is also a simplified view in Plan View.
Solved! Go to Solution.
2025-09-14
08:18 PM
2025-09-15
10:38 PM
We'll I'm embarrassed to say that I figured out what the problem was. It was definitely user error. There is a setting under MVO "Construction Element Options". The skylight was set to "Show Opening Only" instead of "Show Entire Skylight". Thank you, everyone, for your suggestions. I had no idea there were so many ways to hide a skylight from view.
2025-09-10 07:44 PM
Is the Section on the left screenshot using the "Plans - Documentation" MVO Combination shown in the right screenshot? You should see it on the Options Bar below the Section Window.
2025-09-10 10:14 PM
Hi, and thank you. Yes, it is using the same "Plans - Documentation" MVO. Just for fun, I also tried every other MVO that I have set up, and it always has the same result.
2025-09-10 10:41 PM
What is the name of the Skylight Library Part you are using, and which library or library pack is it located in?
2025-09-10
11:04 PM
2025-09-12
11:25 PM
It's the "Skylight Flat Panel" and is in the Basic Library. I have attached a screenshot. This situation occurs with all the skylights in this library pack.
2025-09-12 11:56 PM
Maybe the 3D Detail Level setting in not set to "By Mode View Options".
Using the following settings I could get the same result as you. In this case, Model View Options settings are disregarded.
2025-09-13 01:36 AM - edited 2025-09-13 01:37 AM
Thank you. I'm afraid that I do not have a "Detail Level..." setting option in my library. Also, I just checked, and I have the most up-to-date libraries. I also tried unloading and reloading the Skylight Libpack to see if that would help. It didn't.
2025-09-13 12:36 PM
I see. I guess you are using the Ac28 version while I was checking the Ac29 Tech Preview version first.
I do not see anything else in its settings that would make it disappear in section like this.
I am supposing that you can see the 3D geometry of the Skylight in 3D, it is only the Section that is the problem.
There are two other things I can think of, both can be View-specific:
2025-09-13 12:51 PM
I have something similar happening to stairs from time to time. I see them in plan but not in section or elevation. I found out that changing their renovation status, for example from Existing to Demo and back solved the issue.
2025-09-13 11:36 PM
Thank you, I have checked the Renovation status, and everything in my model is in the Existing option since it is a new design. I also checked my Design Options and can confirm that I have no Design Options besides the "Main Model". Maybe I should look into using the Ac29 Tech Preview.
