3 weeks ago
- last edited
3 weeks ago
I am using AC 28.3.0 on macOS Sequoia on an M3 MacBook Pro. I have been having difficulty getting any skylight object to show up in the section view. All I see is the hole in the roof. It appears to be set to a simplified setting somewhere, but I cannot find where to adjust it that I haven’t already set. The detail skylight is visible in 3D. It is also a simplified view in Plan View.
Solved! Go to Solution.
3 weeks ago
Thank you, that is a good idea. I tried that and changed it to new and back, and then again to demo and back. Unfortunately, it didn't help in this case.
3 weeks ago
- last edited
3 weeks ago
Hi SPR8364,
That's right in the 28 version there's no "Detail Level" specific menu in the settings but you can find them in the All Parameters one.
3 weeks ago
Hi BrunoH,
Merci, I tried that option also, and for some reason, changing that parameter did not change the section or plan appearance. I tried all four setting options in 2D and 3D, and the view stayed the same.
3 weeks ago
- last edited
3 weeks ago
We'll I'm embarrassed to say that I figured out what the problem was. It was definitely user error. There is a setting under MVO "Construction Element Options". The skylight was set to "Show Opening Only" instead of "Show Entire Skylight". Thank you, everyone, for your suggestions. I had no idea there were so many ways to hide a skylight from view.
3 weeks ago
Oops, I forgot about that. Glad that you managed to figure it out.
