Amuni PDF convertor not working with XP 64bit
i'm using Archicad version 9, on windows XP 64bit (SP2)
the amuni PDF convertor, or publishing PDF's from plotmaker will not work either.
is there a way of updating my amuni pdf convertor, without having to pay for it?
Not the Amyuni PDF convertor.
But there are other PDF convertors out there if you Google them - some are free.
Has been discussed in other posts here as well.
The only thing is using another PDF convertor means you can't publish and "Save" a PDF (as that requores the Amyuni convertor).
You can only publish and "Print" to the new PDF convertor.
Or upgrade to version 12.
I think built in PDF convertor of version 11 also works on 64 bit.
Version 10 definitely does not either.
