Craig Bagley
Unexplained fill appearance in column
Problem (using AC11): A 2 ft. tall square column (and therefore uncut) shown on a floor plan with the following settings:
Floor Plan Display: Projected
MVO setting for Cut Fill Patterns: Solid
Basically, one is looking at the top of the column. The line type/pen for uncut lines shows correctly, but a solid fill is added (pen #1 in my case) that I can't trace to any setting anywhere. The fill goes away when I change the MVO setting for Cut Fill Patterns from "Solid" (which strikes me as odd, because the element is not "cut").
Creating a wall with similar settings (i.e. - 2 ft. tall, etc.) seems to behave as expected (no solid fill visible on the floor plan view).
I can also change the height of the column so that it IS cut, or change the Floor Plan Display to something else like Symbolic Cut, and it displays correctly, including the correct pen settings for the fill color.
There are obvious workarounds (no help needed in that respect), but I can't explain the presence of the fill in the column. What am I missing?
AC27 USA/Build 5030 16" MBP
Apparently a bug in 11. It works properly in 12.
Sorry.
Karl
