‎2006-01-20
10:10 PM
‎2023-05-19
04:04 PM
Gordana Radonic
‎2006-01-21 05:14 PM
‎2006-01-23 04:37 AM
matt.pastula wrote:-Don't publish; select items in navigator and Print.
Two weeks later I went to publish/print a layout sheet to PDF and ended up with a big problem, I couldn’t.
To complicate matters more, my Acrobat PDF writer 5.0 will no longer publish PDF’s correctly in PlotMaker or ArchiCAD. It substitutes all the text on the sheet with random numbers and letters that can’t be distinguish as any known language. Even with the box checked to embed all fonts.
‎2006-01-23 02:50 PM
‎2006-01-23 02:59 PM
‎2006-01-26 06:12 PM
‎2006-01-27 01:32 PM
‎2006-01-30 03:40 PM
chad.lawson wrote:We have standardized on Arial in ArchiCAD and PlotMaker. The Tech. support guy just sent me a freeware PDF creator (PDF factory 1.42) that worked fine. It might be time to upgrade our Acrobat from 5 to the latest version. It still doesn't explain the original problem I was having with my old Acrobat or current Amyuni driver.
Out of curiousity, what font are you using in your .pln and .lbk files?
‎2006-01-30 03:42 PM
miker wrote:This doesn't work. See my original post.
Don't choose the "Amyuni" printer ,choose the "Adobe PDF"
