Views, layouts, publishing: seamless Archicad documentation
Amyuni PDF Printing Problem
I’ve recently upgraded our office’s five licenses of ArchiCAD to version 9 (I know, I know, just in time for version 10 to be released) about six week ago and have had sever PDF printing problems. Installations were fairly easy, installed using ArchiCAD CD, then downloaded and installed latest hot fix 2172. Two weeks later I went to publish/print a layout sheet to PDF and ended up with a big problem, I couldn’t.
Once I clicked publish/print (like I’ve done many times successfully in the previous version) it sent the job to the print queue and sat there. It wouldn’t even let me delete it; I had to restart my computer to remove the item from the queue. PlotMaker would freeze up after every try made. I tried deleting the preferences and letting the program create new default without avail. I even tried setting the port assignment from LPT1 to others with the same results.
The problem exists in ArchiCAD and PlotMaker using both the print and publish functions.
To complicate matters more, my Acrobat PDF writer 5.0 will no longer publish PDF’s correctly in PlotMaker or ArchiCAD. It substitutes all the text on the sheet with random numbers and letters that can’t be distinguish as any known language. Even with the box checked to embed all fonts.
Any help on the situation would be appreciated.
8 REPLIES 8
When i try to use the Amyuni i had some problem with the fonts
http://archicad-talk.graphisoft.com/viewtopic.php?t=9270&highlight=
Get the adobe PDF printer ,is much much better
I never had a problem with it
Erika Epstein
-Don't publish; select items in navigator and Print.
Uncheck that 'box checked to embed all fonts.'
and remember not to check the save to file
HTH\
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Erika:
Opps, the 'publish/print' that I indicated was that my problem exists when I us the publish function in both ArchiCAD and PlotMaker, as well as the print function by selecting from the navigator as you suggested.
Also tried unchecking the 'embed all fonts' box which amounts to the same problem. I never check the 'save to file' box.
Very strange problem. Never have this happen in version 8.1.
Matt
Miker:
Tried all the items in your suggested link with no change in the problem. My Acrobat 5.0 still saves the PDF file correctly but with the font problem. Acrobat still works with any other program on my computer. It has to be something between ArchiCAD, PlotMaker and the Amyuni print driver.
Still don't understand why this problem is occurring.
Matt
I can't stand using the amyuni printer, that things a pig. Out of curiousity, what font are you using in your .pln and .lbk files? I have changed all of our default fonts to arial for our plan documentation (this keeps things uniform, and when we export to autocad, I don't have to build a huge font translation table). I am currently using Adobe's Acrobat 7.0 without any problem whatsoever.
Don't choose the "Amyuni" printer ,choose the "Adobe PDF"
We have standardized on Arial in ArchiCAD and PlotMaker. The Tech. support guy just sent me a freeware PDF creator (PDF factory 1.42) that worked fine. It might be time to upgrade our Acrobat from 5 to the latest version. It still doesn't explain the original problem I was having with my old Acrobat or current Amyuni driver.
Tech. support and I are still exchanging emails, we'll see if they have a fix for the problem. Stay tunned.
This doesn't work. See my original post.
